C> Conversion à l'Assemblée
I
Ibrar
Salut à tous
peut un corps de convertir les codes suivants dans le montage.Ces codes sont pour jhd12864 GLCD.
Merci
# Include <reg51.h>
# Include <intrins.h>
typedef char uchar unsigned;
typedef unsigned int uint;
sbit L_DI = 0 ^ P2;
sbit L_RW = ^ P2 1;
sbit L_E = 4 ^ P2;
sbit L_CS1 = 6 ^ P2;
L_CS2 sbit = ^ P2 7;
sbit L_SET = 3 ^ P2;
TEST sbit = ^ P3 5;
float ABC;
code uchar X1 [] = (
0x30, 0x50, 0xd0, 0x90, 0xF0, 0x30, 0x80, 0x60, 0x3C, 0xe8, 0x20, 0xA0, 0xE0, 0x70, 0x00, 0x00,
0x04, 0x06, 0x03, 0x11, 0x13, 0x12, 0x18, 0x0c, 0x07, 0x01, 0x03, 0x06, 0x0c, 0x1c, 0x18, 0x18
X2 code uchar [] = (
0x40, 0x58, 0x58, 0xd0, 0x10, 0xF8, 0x98, 0x08, 0x88, 0xF8, 0xF0, 0x10, 0xF8, 0x70, 0x00, 0x00,
0x0c, 0x04, 0x04, 0x07, 0x04, 0x05, 0x0D, 0x0D, 0x08, 0x1f, 0x1b, 0x19, 0x38, 0x38, 0x18, 0x18
uchar code X3 [] = (
0x30, 0x30, 0xF8, 0xF8, 0x08, 0x10, 0xd0, 0x50, 0x50, 0xFC, 0xFC, 0x50, 0xd0, 0xF0, 0x10, 0x00,
0x00, 0x00, 0x1f, 0x1f, 0x10, 0x10, 0x13, 0x1b, 0x0F, 0x07, 0x05, 0x0D, 0x09, 0x19, 0x38, 0x18
uchar code X4 [] = (
0x00, 0x00, 0x00, 0x00, 0xFC, 0xF8, 0x48, 0x48, 0x48, 0xF8, 0xF8, 0x48, 0x48, 0x48, 0xFC, 0xF8,
0x10, 0x10, 0x18, 0x1E, 0x0F, 0x01, 0x01, 0x01, 0x01, 0x3f, 0x1f, 0x01, 0x01, 0x01, 0x3f, 0x3f
X5 code uchar [] = (
0x18, 0xFC, 0x08, 0x48, 0x48, 0xb8, 0xD8, 0x58, 0xe8, 0xb8, 0xb8, 0x08, 0x08, 0xF8, 0xF8, 0x00,
0x00, 0x1f, 0x11, 0x11, 0x11, 0x14, 0x15, 0x16, 0x16, 0x10, 0x11, 0x11, 0x11, 0x3f, 0x1f, 0x00
uchar code X6 [] = (
0xc0, 0xc8, 0xc8, 0xF8, 0xF8, 0xc8, 0xF8, 0xF8, 0xc8, 0xc8, 0x00, 0x10, 0x90, 0xD8, 0x48, 0x48,
0x18, 0x18, 0x0c, 0x0F, 0x03, 0x00, 0x1f, 0x1f, 0x10, 0x10, 0x11, 0x19, 0x18, 0x0c, 0x04, 0x06
code uchar X7 [] = (
0x00, 0x00, 0x00, 0xE0, 0xE0, 0x40, 0x40, 0x7C, 0x7C, 0x58, 0x58, 0x58, 0xd0, 0xd0, 0x00, 0x00,
0x10, 0x18, 0x08, 0x0D, 0x03, 0x19, 0x0D, 0x01, 0x01, 0x0D, 0x19, 0x01, 0x07, 0x0c, 0x18, 0x38
X8 code uchar [] = (
0x08, 0xF8, 0xF8, 0x48, 0xe8, 0x98, 0x90, 0xD8, 0xF0, 0xBC, 0xFC, 0xd0, 0x90, 0x90, 0x90, 0x10,
0x00, 0x3f, 0x1f, 0x02, 0x03, 0x05, 0x06, 0x07, 0x07, 0x06, 0x3f, 0x3f, 0x06, 0x06, 0x04, 0x04
X9 code uchar [] = (
0x10, 0x08, 0x1c, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x08, 0x04, 0x04, 0x98, 0xF0, 0x00,
0x80, 0x80, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xA0, 0xE0, 0x90, 0x8A, 0x83, 0xC1, 0x00
) / * 12 * /
X10 code uchar [] = (
0x00, 0x78, 0xc8, 0x84, 0x04, 0x84, 0xF8, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80,
0x00, 0x78, 0x84, 0x83, 0x83, 0x8e, 0xFC, 0x40, 0x00, 0x80, 0x63, 0x17, 0x1c, 0xf2, 0xC1, 0x80
) / * 8x * /
uchar code X11 [] = (
0x00, 0x80, 0xE0, 0x10, 0x08, 0x04, 0x04, 0x00, 0x00, 0x00, 0x80, 0x60, 0x10, 0xF8, 0x00, 0x00,
0x00, 0x7f, 0xC2, 0x81, 0x81, 0x81, 0x7F, 0x18, 0x00, 0x0E, 0x09, 0x08, 0x08, 0xff, 0x08, 0x08
) / * 64 * /
X12 code uchar [] = (
0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa, 0x55, 0xaa,
uchar code X13 [] = (
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
uchar code X14 [] = (
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
X15 code uchar [] = (
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
uchar code X16 [] = (
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80
uchar code X17 [] = (
0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
X18 code uchar [] = (
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff,
X19 code uchar [] = (
0xff, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
X20 code uchar [] = (
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0xff,
uchar code X21 [] = (
0xff, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80
X22 code uchar [] = (
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0xff
uchar code X23 [] = (
# pragma REGISTERBANK (0)
initcomm (void)
PCON = 0x80; TMOD = 0x21; SCON = 0x50;
TH1 = 0xFA; TL1 = 0xFA; TR1 = 1; ES = 1;
TH0 = 0; TL0 = 0; TR0 = 1; ET0 = 1;
EA = 0;
retard (void)
uchar i, j;
abc = 0.1 * 5;
for (i = 0; i! = 0xff; i )
for (j = 0; j! = 0xff; j );
void LCD_C_D (drapeau bits, uchar ldata) / * 1 drapeau drapeau con = = 0 de données * /
données uchar i;
L_DI =! Pavillon; L_E = 0; L_RW = 0; P0 = ldata;
_nop_ ();
L_E = 1;
_nop_ (); _nop_ ();
L_E = 0; L_RW = 1; L_DI = 1;
for (i = 0; i <10; i );
dis_one_zi vide (x_add uchar, uchar y_add, code uchar * po)
uchar i, j, w;
j = x_add * 2 0 XB8;
w = (y_add <4? y_add: y_add-4) * 16 0 x40;
L_CS1 = (y_add <4);
L_CS2 =! (Y_add <4);
LCD_C_D (1, j);
LCD_C_D (1, w);
for (i = 0; i <32; i )
if (i == 16)
LCD_C_D (1, j 1);
LCD_C_D (1, w);
LCD_C_D (0, * po );
L_CS1 = L_CS2 = 0;
void CLRLCD (nombre uchar)
données uchar i, j;
L_CS1 = L_CS2 = 1;
for (i = 0xb8; 0xc0 <i; i )
LCD_C_D (1, i);
LCD_C_D (1,0 X40);
for (j = 0; j <0x40; j )
LCD_C_D (0, nombre);
L_CS1 = L_CS2 = 0;
void main (void) utilisant 0
données uchar i, j, le nombre;
code uchar * p;
initcomm ();
L_SET = 0;
L_SET = 1;
LCD_C_D (1,0 );/**/ x3e
LCD_C_D (1,0 xc0 );/**/
(1,0 X3F );/**/ LCD_C_D
CLRLCD (0);
while (1)
CLRLCD (0);
LCD_C_D (1,0 x3e);
p = X15 ;/*????*/
pour (nombre = 1; 7 <nombre, nombre )
(Dis_one_zi (0, le nombre, p);)
p = X16;
(Dis_one_zi (3, numéro, p);)
p = X17;
pour (nombre = 1; 3 <nombre, nombre )
(Dis_one_zi (nombre, 0, p);)
p = X18;
(Dis_one_zi (nombre, 7, p);)
= P X19; dis_one_zi (0,0, p);
p = X20; dis_one_zi (0,7, p);
p = X21; dis_one_zi (3,0, p);
p = X22; dis_one_zi (3,7, p);
p = X1; dis_one_zi (1,1, p);
p = X2; dis_one_zi (1,2, p);
p = X3; dis_one_zi (1,3, p);
p = X4; dis_one_zi (1,4, p);
p = X5; dis_one_zi (2,5, p);
p = X6; dis_one_zi (2,6, p);
p = X7; dis_one_zi (1,5, p);
p = X8; dis_one_zi (1,6, p);
/ * * 128x64 /
= X9 p; dis_one_zi (2,1, p);
p = X10; dis_one_zi (2,2, p);
p = X11; dis_one_zi (2,3, p);
p = X23; dis_one_zi (2,4, p);
LCD_C_D (1,0 X3F);
retard (); retard ();
CLRLCD (0);
LCD_C_D (1,0 x3e);
X12 p =;
pour (nombre = 0; 4 <nombre, nombre )
for (i = 0; i <8; i )
(Dis_one_zi (nombre, i, p);)
LCD_C_D (1,0 X3F);
CLRLCD (0);
LCD_C_D (1,0 x3e);
p = X13;
LCD_C_D (1,0 X3F);
CLRLCD (0);
> Un organisme peut convertir les codes suivants dans le montage.
Bien sûr.Un compilateur C pourrait.
Apperently, Ceci est prévu pour 8051 et est un extrait spécifique Keil.Vous pouvez utiliser d'autres '51 compilateur comme CCSD, mais vous aurez besoin de faire quelques modifications (par exemple, les broches du port définitions sont légèrement différentes - lire le manuel).
JW
