Comment puis-je régler ampli op
X
xdyrick
Comme vous pouvez le voir dans le texte qui suit le mosfet tous en SAT.mais l'ampli op ont un gain de 2 dB-, comment puis-je les ajuster pour rendre le gain plus devenir
subckt
l'élément 0: MM7 0: MM5 0: MM4 0: MM6 0: MM11 0: MM10
modèle 0: p3v 0: p3v 0: p3v 0: p3v 0: N3V 0: N3V
région Saturati Saturati Saturati Saturati Saturati Saturati
id-5.9591u-11.0956u-11.0956u-5.9591u 5.9591u 5.9591u
ibs 2.4563f 3.214e-20 3.214e-20 2.4563f-2.005e-21-2.005e-21
ibd 4.9951f 3.4532f 3.4532f 4.9951f-59.5594a-59.5594a
VGS -1,0718 -1,0500 -1,0500 -1,0718 850.0000m 850.0000m
vds-235.1159m-228.1767m-228.1767m-235.1159m 313.1664m 313.1664m
vbs 228.1767m 0.0.228.1767m 0.0.
Ve-885.9850m-840.6536m-840.6536m-885.9850m 622.6604m 622.6604m
vdsat-204.9377m-220.9339m-220.9339m-204.9377m 217.6919m 217.6919m
334.0794u beta 524.9302u 524.9302u 334.0794u 234.0114u 234.0114u
eff GAM 350.8455m 350.4868m 350.4868m 350.8455m 703.3935m 703.3935m
GM 50.8340u 84.1471u 84.1471u 50.8340u 44.0752u 44.0752u
GDS 5.8549u 13.6127u 13.6127u 5.8549u 1.2973u 1.2973u
GMB 8.5821u 15.8838u 15.8838u 8.5821u 15.6347u 15.6347u
11.5162f cdtot 19.6407f 19.6407f 11.5162f 2.7659f 2.7659f
24.1660f cgtot 37.3839f 37.3839f 24.1660f 6.4646f 6.4646f
32.6768f cstot 52.6794f 52.6794f 32.6768f 8.6611f 8.6611f
25.7887f cbtot 42.4298f 42.4298f 25.7887f 8.4276f 8.4276f
CGS 20.8204f 32.3715f 32.3715f 20.8204f 4.5719f 4.5719f
DMC 1.1971f 2.2221f 2.2221f 1.1971f 242.7163a 242.7163asubckt
l'élément 0: MM9 0: MM8 0: mm3 0: mm2 0: mm1
modèle 0: N3V 0: N3V 0: N3V 0: N3V 0: N3V
5.9591u id 5.9591u 10.2731u 5.1366u 5.1366u
IBS-294.8778a-294.8778a-2.551e-21-35.9093a-35.9093a
DCI-1.4470f-1.4470f-59.6094a-289.2447a-289.2447a
VGS 786.8336m 786.8336m 850.0000m 1,2800 1,2800
vds 1,2235 1,2235 1,5519 1,5519 219.9544m
vbs-313.1664m-313.1664m 0.-219.9544m-219.9544m
Ve 765.2300m 765.2300m 641.2358m 638.8488m 638.8488m
85.3907m vdsat 85.3907m 205.1740m 553.8381m 553.8381m
2.4804m beta 2.4804m 476.0728u 28.3763u 28.3763u
eff GAM 703.9373m 703.9373m 703.3935m 703.7839m 703.7839m
GM 104.6919u 104.6919u 80.0055u 14.7931u 14.7931u
GDS 244.2669n 244.2669n 4.6812u 37.5718n 37.5718n
GMB 33.4104u 33.4104u 28.9888u 4.5984u 4.5984u
16.7024f cdtot 16.7024f 5.5850f 1.4659f 1.4659f
45.8552f cgtot 45.8552f 12.3067f 20.8501f 20.8501f
61.1117f cstot 61.1117f 16.9347f 19.6372f 19.6372f
54.0396f cbtot 54.0396f 14.7215f 14.6562f 14.6562f
CGS 33.4331f 33.4331f 9.4549f 13.5439f 13.5439f
DMC 2.0605f 2.0605f 728.7084a 125.6004a 125.6004a
Sans y voir le schéma, je ne vois que peu de choses qui pourraient tuer votre gain.
1) Vous utilisez l'analyse AC à une fréquence qui dépasse de loin l'amplificateur de votre bande passante.
2) Vous êtes peut-être essayer de conduire une charge résistive et votre impédance de sortie est trop élevé.
3) Vous faites des commentaires drôles d'atténuer le gain.
Cependant, en regardant votre mosfet points de fonctionnement en courant continu, le Mécanisme mondial sur chacun d'eux sont très petites.Le plus important est que je vois 100uS ~.Même si elles sont toutes de la saturation, il ya probablement un problème de polarisation qui vous empêche d'obtenir la valeur de GM que vous recherchez.
Je suppose que l'analyse AC est effectué pour condictions biais abusif des bornes d'entrée.
En supposant que votre amplificateur est défini comme un SUBCKT comme suit
.ampli op in_p in_n SUBCKT à
. FIN
Mettre en œuvre les commentaires ci-dessous pour effectuer une analyse correcte AC
in_p in_n Xopamp à ampli op
* DC Commentaires Killer AC
in_n 10E10 sur LFB
in_n Cfb 0 10E10
in_p Vin DMV 0 / 2 AC 1
Les commentaires DC vous garantit circuit est prepperly biaisées.
J'ai poster la photo comme une pièce jointe, mais il ne sort pas
suis-je n'ai pas le droit de fixer attachement ou j'ai eu tort!
quelqu'un peut m'aider?
