vhdl-ams avec ncvhdl
sebgimi
New member
Bonjour a tous et bonne annee!
J'essaye de modeliser un comparateur en vhdl-ams sur le logiciel ncvhdl mais je n'arrive pas a corriger les erreurs a la compilation...
Voici mon code:
--library ieee;
--use ieee.electrical_systems.all;
library ieee, disciplines;
use ieee.std_logic_1164.all;
use disciplines.electrical_system.all;
entity comparateur is
	generic (level : real := 2.5; -- seuil
		 vcc   : real := 5;   -- etat haut sortie
		 gnd   : real := 0);  -- etat bas sortie
	port(terminal e, ref: electrical;  -- entree analogique
             signal   s: out std_logic); -- sortie numerique
end comparateur;
architecture simple of comparator is
quantity v across e;       -- across quantity to ground
begin
     s <= `1' when v'Above(level) -- v > level
     else `0';                    -- v < level
end architecture;
Voici mes erreurs:
ncvhdl -work st_lib -message ../sources/comparateur_ent.vhdl
ncvhdl: 13.10-s013: (c) Copyright 1995-2013 Cadence Design Systems, Inc.
../sources/comparateur_ent.vhdl:
ncvhdl_p: *E,MISCOL (../sources/comparateur_ent.vhdl,14|15): expecting a colon (':') 87[4.3.3] 93[4.
3.2].
ncvhdl_p: *E,ENNOFN (../sources/comparateur_ent.vhdl,19|32): Intermediate file for entity 'COMPARATO
R' could not be loaded, entity may require re-analysis.
ncvhdl_p: *E,EXPBEG (../sources/comparateur_ent.vhdl,19|37): expecting the reserved word 'BEGIN' [1.
2].
ncvhdl_p: *E,UNKCCS (../sources/comparateur_ent.vhdl,21|9): unknown concurrent statement [9].
ncvhdl_p: *E,UNKCCS (../sources/comparateur_ent.vhdl,21|11): unknown concurrent statement [9].
ncvhdl_p: *E,UNKCCS (../sources/comparateur_ent.vhdl,21|18): unknown concurrent statement [9].
ncvhdl_p: *E,EXPEND (../sources/comparateur_ent.vhdl,21|21): expecting the reserved word 'END' [1.2]
ncvhdl_p: *E,ILLPRI (../sources/comparateur_ent.vhdl,25|10): expecting an expression or operand [7.1
] [7.3].
end architecture;
ncvhdl_p: *E,EXPACN (../sources/comparateur_ent.vhdl,28|16): expecting an architecture name [1.2].
        errors: 9, warnings: 0
En fait quand je regarde sur internet il y a plein de librairies differentes pour cette extension du vhdl, peut etre que je n'utilise pas les bonnes, peut etre qu'il y a des librairies specifiques au logiciel que l'on utilise. Comme vous le voyez je suis perdu, toute aide serait la bienvenue. Merci d'avance!
